Author Topic: Torque andriod app  (Read 8524 times)
Offline gm8
Torque andriod app
« on: 04 April 2013, 15:37 »
Is there any way to get this working on an AGU ? It reads codes etc from my old mans freelander no probs. From what i have read it works on AUM and above , just wondered if there is any ways to get working on an AGU
Offline godsANGER
  • The black Money PIT - TDi ARG MONSTER! lol
Re: Torque andriod app
« Reply #1 on: 04 April 2013, 15:54 »
what do you mean get it working ? cant you connect to the dongle or the ECU ?
from my exsprance with it dose not bring all the fault codes up when, scan my mk4 TDi AGR with torgue app no faults found when i use vcds picked up two.
So i only use it as a novelty thing and at the min to check my engine temp as my temp sensor is gone so dosnt show on my clocks.
Repairs Since 12/09 = £1860.00  *  Follow me on INSTAGRAM = w_all_ace
! thePOORmansBUILD !
Offline gm8
« Reply #2 on: 04 April 2013, 16:13 »
both really. Works fine in the freelander thought. I have read its to do with the port in the AGU ?
Offline Wazzzer
  • Golf GTI 1.8T AGU
« Reply #3 on: 04 April 2013, 16:41 »
Nope, doesn't work and no way of getting it to work AFAIK
Offline godsANGER
« Reply #4 on: 04 April 2013, 16:43 »
may not be able to, but i got told it wouldnt work on my TDi  but when i connect it i have to have engine off first then plug the OBD2 dongle in let it flash for a bit till stops then open app so it trys to connect then once its failed turn key so dash ligths up and try again works for me every time for me
Offline itavaltalainen
« Reply #5 on: 04 April 2013, 20:53 »
TDIs were OBD2 compatible before petrol....
So will work with some diesels when petrols from same year won't communicate with OBD2 dongles...
Offline benji mk2
  • Soon be christmas!
« Reply #6 on: 13 April 2013, 23:03 »
Agu is obd I, so I'm pretty sure it won't work.
