Author Topic: PLEASE HELP MK4 FRONT STRUT REMOVAL  (Read 1459 times)
Offline shunterdave
« on: 04 April 2013, 11:18 »
Having trouble removing front struts on my mk4 gti so i can fit loer springs did the rears without issue but fronts are being difficult . the balljoint on wishbone is spinning and cant get nut off ? and no room as it hits drive shaft ? tried jack underneath it still spins tried clamping it still spins PLEASE HELP GUYS ! :smiley:
Offline Screech16v
  • MK3 20vt AGU
Re: PLEASE HELP MK4 FRONT STRUT REMOVAL
« Reply #1 on: 04 April 2013, 21:48 »
Hi mate jacking from below the ball joint has worked for me every time may I suggest try jacking again as much as you dare then see if you can shock it with a hammer ,it may just tighten the taper enough to get the nut undone, or cut it below the nut and replace  :smiley:
Offline scarr89
  • Mk4 Golf, DERV FTW!
« Reply #2 on: 04 April 2013, 22:36 »
Which nut?
I just hit the hub with a hammer until the strut came out. I can't remember if I removed the DS or not  :undecided:
Offline Screech16v
  • MK3 20vt AGU
« Reply #3 on: 04 April 2013, 22:43 »
Bottom ball joint nut.
