Author Topic: Speedo needle  (Read 1388 times)
Offline chewychewits
Speedo needle
« on: 01 August 2005, 20:53 »
Im being driven mad by this......
Everytime I accelerate my speedo needle flies up and down like a mad thing on a mad things day out but when Im doing constant speed it settles down.......why is this happening and what can I do to stop it...please help!!!
Offline kniterider
  • had most, sold most and often buy more!
Re: Speedo needle
« Reply #1 on: 01 August 2005, 21:10 »
either 1 of 2 things.....
broken speedo cable (cable snapped with in the outer sleeve, yet they still touch) this can give the effect you described then it will stop working all together) ive had this on my old mk1 rocco
just disconnect the cable at either end and make sure the 'inner' is not broken (in one piece).
or its one of the pieces within the speedo unit its self, these can be stripped for a visual inspection to see whats broken but its magnifiying glass and tweezers job, or best bet is to buy a set of second hand clocks for somewhere like ebay for around £10
Gaz
mix
Re: Speedo needle
« Reply #2 on: 01 August 2005, 22:01 »
Mine used to do this, but being the lazy git i am i never sorted it.....
sonds like a worn speedo jibby (dont know the technical name) to me . . . . probably get a new one on the cheap from GSF....
Re: Speedo needle
« Reply #3 on: 02 August 2005, 12:57 »
I fixed mine with a little surgery to the speedo cable, there were spots where the outer sheathing had worn away and you could see the inner cable.  What I did was trim away any damaged outer sheathing, and make sure there were no bits caught in the gaps. I then sprayed WD40 into the gaps, wiped off the excess and covered the damaged areas with some duck tape.  After a couple of days the needle was smooth as silk :cool:
I also found rerouting the cable helped reduce the wobble a bit, I cable tied mine to the top of the bay under the scuttle cover, keeping it away from any vibrating engine components and made sure there were no tight bends in the cable.
Note: The inner cable runs inside a spiral shaped metal core, then has a rubber outer sheath round it. When the rubber sheath wears it gets forced into the gaps in the core and rubs on the inner cable.  Sounds complicated but you'll know what I mean when you see it  :grin:
