Author Topic: clocks - temp gauge not working  (Read 5985 times)
Offline godsANGER
  • The black Money PIT - TDi ARG MONSTER! lol
« on: 02 April 2013, 11:00 »
Hiya all
Yestarday noticed my temp gauge wasn't working on my clocks after doing 40miles trip. So pluged in my wireless obd2 connector and used my torque app and the temp went up and sat at 80 on the app after the same trip.
Dose this sound like the clocks are fubar,d ? Still need to scan it but won't be able to do that till tonight.
Thanks Mike
Repairs Since 12/09 = £1860.00  *  Follow me on INSTAGRAM = w_all_ace
! thePOORmansBUILD !
Offline godsANGER
Re: clocks - temp gauge not working
« Reply #1 on: 02 April 2013, 13:28 »
littlebump
Offline rio_gti
« Reply #2 on: 02 April 2013, 15:53 »
scan it.... or just test the display using vagcom!!!
Offline godsANGER
« Reply #3 on: 02 April 2013, 16:28 »
how do you test the display ?
Offline Rhyso
« Reply #4 on: 02 April 2013, 22:32 »
Go into the module and there is an option to perform output tests
Offline godsANGER
« Reply #5 on: 03 April 2013, 15:33 »
Thanks ill give it a bash tonigth
Offline godsANGER
« Reply #6 on: 03 April 2013, 21:58 »
tested the clocks in vcds and clocks work fine  :grin:
So just to double check going to stick the old temp sensor if can find it and test it.
Code from vcds
Control Module Part Number: 038 906 012 K
  Component and/or Version:  1,9l R4 EDC 0000SG  2811
           Software Coding: 00002
            Work Shop Code: WSC 00028
1 Fault Found:
17664 - Engine Coolant Temp Sensor (G62): Open or Short to Plus
        P1256 - 35-10 - - - Intermittent
« Last Edit: 03 April 2013, 22:04 by godsANGER »
