Author Topic: New member looking for advice  (Read 1626 times)
Offline mattrix
« on: 02 April 2013, 10:35 »
Hey, just joined the site today and already have a question.
I have a Mk1 golf GTI cab stored in a garage which has been untouched for about 15 years and was finally going to get around to getting her back on the road.  Obviously after sitting for so long fluids and filters and what not will need to be changed before trying to turn her over but can anyone give me any advice on what else i should take a look at before doing so.
Thanks
Offline antogoof
  • bbm mk2 g60
Re: New member looking for advice
« Reply #1 on: 02 April 2013, 12:11 »
fluid and filter deffo, but you will probably have perished hoses and the clutch might be kaput, other than that id say turn her over, oh and some fresh petrol, if you have any in the car now it needs draining id say. :smiley:
mk2 bright blue met bits wanted in north west.
Offline mattrix
« Reply #2 on: 02 April 2013, 12:26 »
Yeah i was planning on draining the tank of any old fuel although thinking about it now being an 86 not actually sure if it runs on unleaded or the old 4*.  So i guess its worth changing plugs to.
Offline Jimble
« Reply #3 on: 02 April 2013, 19:15 »
Have a check of the belts as well to make sure they're not perished.
Offline justalex81
« Reply #4 on: 03 April 2013, 19:14 »
turn engine over by hand before you crank it. drop of oil in the bores.
Offline Screech16v
  • MK3 20vt AGU
« Reply #5 on: 04 April 2013, 20:02 »
I would put a splash of diesel in the bores ,its very searching and will help free up any stuck piston rings
