The garage
smelly when raining!!!
Topic: smelly when raining!!! (Read 1539 times)
bjsj
01 August 2005, 18:27 »
is response to my previous post, my gti dosen't smell too bad now, however if it rains the smell comes back very strong, as i say, like sweet pissy flowers, anybody any ideas?
please!!!
kniterider
had most, sold most and often buy more!
Re: smelly when raining!!!
01 August 2005, 18:29 »
pissy flowers...... cant say i know they smell like, what mk of car you got thats smellin like that??
Mr Blue
Forum addict
01 August 2005, 18:37 »
what you do is... open the bath taps. jump in and the smell should go away
only kiddin
sure the coolant isnt leaking inside the car from the matrix. that can stink
is the carpet wet? could be the sound proofing that smells if water enters the car
check the plastic scuttle trays and the bonnet tray
Last Edit: 02 August 2005, 11:02 by Baby Blue Mk2
rubjonny
10k hero
Hello, my name is John and I'm a dub addict.
02 August 2005, 12:47 »
Lift up the plastic scuttle trays and have a good look under there, sounds like summat is rotting away in it. It'll make it into the cabin cos thats where the fresh air intake is. Also check the seal round the base of the fan and have a look inside it might be full of leaves!
One last thing check the rubber seal is present along the metal lip at the front of the plastic scuttle, this seals the bay from engine smells
bjsj
04 August 2005, 18:50 »
ta lads, but the heater matrix is fine,the carpets arn't wet,all the seals are in tack,and the trough is clear, but thanks lads!! any more takers?? please
Mr Blue
Forum addict
04 August 2005, 19:52 »
have a look at the state of the windscreen washer pipes. Screen wash can stink
rubjonny
10k hero
Reply #6 on:
04 August 2005, 21:49 »
Good point! The screenwash in my girlfirends AX smelt like vomit
marcogolfo
Freelance Web Design, Logo Design etc email me
Reply #7 on:
05 August 2005, 12:14 »
soundproofing smells alot like piss when its wet, if it has got wet then i suspect it will never dry
bjsj
Reply #8 on:
08 August 2005, 20:33 »
ta lads, the only thing is, the smell goes when i either put the air con on, or set the air to recirculate, any more ideas, by the way the washer fluid that the dealer put in smells like fairy liquid!!
The garage
