Author Topic: is all mk4 golf suspension/anti roll bars the same?  (Read 1160 times)
Offline gttjames
Doing some suspension swapping, need some standard shocks/springs and anti roll bar. Does the suspension/anti roll bars off say 1.6 petrol's/1.9tdi's the same as the 1.8t?
Also does anyone know, if I fit the modified anti roll bar to my golf with the more clearance on driveshafts - will it be ok if I don't lower the car ( as might fit the anti roll bar 1st, then get the lowering kit next month say?)
Offline golfyste
  • Project track car
Re: is all mk4 golf suspension/anti roll bars the same?
« Reply #1 on: 01 April 2013, 09:26 »
Suspension is different on different models due to difference in weights and also I think the gti suspension is slightly lower
I don't really know about the arb's
But .... Although they are different specs they will still fit as they all have the same fitment just difference strength/thickness springs and arb's
Offline gttjames
« Reply #2 on: 01 April 2013, 10:44 »
arg right I see, hmm so its to which they left factory on, im guessing some of the v5's/tdi's could have the same
iv read 2 options for anti roll bar 21/23mm - are they interchangeable providing correct bush size is used with bar?
Offline SI74
« Reply #3 on: 01 April 2013, 11:33 »
Yes
Offline gttjames
« Reply #4 on: 01 April 2013, 12:30 »
thanks :smiley:
