couple of questions on r32 cooling system.
should the auxiliary pump be working on "ignition on" and also after the car has been started and turned off? I believe the pump is meant to run for 5-10mins...how is it controlled?
should the fans when activated pulse on and off e.g run for 10 secs and then turn off and continue to do this every few mins or so?
cheers
