Author Topic: S3 front brakes on golf  (Read 1579 times)
Offline turbokid23
« on: 31 March 2013, 15:06 »
As title says am thay A strate swop over or do I need mods? Got all the carriers and that cheers ppl
Offline turbokid23
Re: S3 front brakes on golf
« Reply #1 on: 31 March 2013, 16:29 »
Eney 1 plz as I can buy sum for £20 :)
Offline brewey
« Reply #2 on: 31 March 2013, 16:40 »
Are they not just the 312mm brakes from the 4motion/ TT?
Either way if you've got everything I think that they'll fit straight on anyway it's the same platform.
2000 1.8T ARZ - OEM+
Offline turbokid23
« Reply #3 on: 31 March 2013, 16:50 »
Cheers mate
Offline brewey
« Reply #4 on: 31 March 2013, 16:53 »
Maybe just measure the disc to check man.
Also it is from the 8L (mk1 s3) model too and not the 8P I presume?
Offline turbokid23
« Reply #5 on: 31 March 2013, 19:17 »
Yeah mate mk1 s3 iv orderd some new disks eney way so shoud be on soon just painting them
Offline navmk4gti
« Reply #6 on: 31 March 2013, 19:51 »
For £20 bargain either way. Aint s3 brakes same as found on lcr? :undecided: should fit if you got calipers etc
Offline Rhyso
« Reply #7 on: 31 March 2013, 19:54 »
LCR had Brembo's; well the top spec did
Offline brewey
« Reply #8 on: 31 March 2013, 20:29 »
Happy days man. Bargain at 20quid. If you find any more send them this way. ;)
Also Nav I'm fairly sure they are just the vag 312. The LCR came with brembo 4pots that are bigger.
Offline ReDBull
« Reply #9 on: 31 March 2013, 22:05 »
LCR has 323mm discs with Brembos in the UK. In Europe Brembos where an option. Useless fact of the day.
03 210 Seat LCR. Badger5 V2.2TIP, Fordge 007p, Wellycooler, Quaife ATB LSD, Nuespeed ARB's, KW Clubsports, 330mm discs, 3" turbo back de cat and still on the standard map!
My project thread: http://www.golfgtiforum.co.uk/index.php?topic=241116.0
