Author Topic: New injectors for a KR  (Read 1806 times)
Offline basssound
« on: 31 March 2013, 14:39 »
Has anyone on here swapped out the standard 16v injectors for the brass Merc Benz 190e ones?
A bit of research has shown that these are a good replacement as the are supposed to be identical
but everything i've found is pointing towards the 8v only.
Are the 16v injectors different?
Cheers.
Offline clipperjay
Re: New injectors for a KR
« Reply #1 on: 31 March 2013, 18:40 »
Yes very different indeedie one has a plastic body usually with a Digi ECU i.e 8V. Other 16ver is made from stainless and brass and is thinner GFS used sell them at about £30 a pop if I remember rightly might be more money!
Make sure you replace all seals from VAG if you plan of swapping them out chances they are finished one smaller seal and a larger insert seal, that's an important one!
Offline Gambit
« Reply #2 on: 01 April 2013, 09:27 »
Merc ones wont come with the top hats. Just look up your local bosch suppler they should be able to source them for you
Offline basssound
« Reply #3 on: 01 April 2013, 16:55 »
I've been lead to believe that the top hats come off after some soaking and then press onto the new injectors.
Offline Gambit
« Reply #4 on: 01 April 2013, 22:13 »
They do indeed. Alternately you could just get your own ones cleaned n checked. And just buy some new seals
Offline basssound
« Reply #5 on: 01 April 2013, 23:00 »
I know mine are leaking when they get hot.
I run the car warm, turn off the ignition and then try to fire it up a few minutes later and it turns over for a while before firing up as the injectors are weeping.
It'll even struggle to start if the ignition is left on for more than 10 minutes.
