Author Topic: N75  (Read 714 times)
Offline daddy5x
  • any time now milltek cat back remap
N75
« on: 30 March 2013, 21:30 »
Guys I'm looking for a bit more poke from my 1.8 turbo. Someone mentioned the 1st thing I should do is add a n75. Relay??? Can someone elaborate on this please
standard gti turbo (aum     4 now
Offline davemk4
Re: N75
« Reply #1 on: 31 March 2013, 07:27 »
Your car all ready has an n75 valve. You can change the n75 to different versions which "can" alter the boost curve but this is very hit and miss if it does. Have you had the car mapped?
2001 mk4 GTI 1.8t AUM. k&n induction kit with customer heat shield, 3'' TIP, Forge 007P, Stage 1 map, N249 bypass, 3'' downpipe and decat, 2.75'' Jetex cat back non res, Koni shockers and H&R springs 35mm, dimpled and grooved disks front and back
