Author Topic: Coil Pack Failed!!  (Read 4109 times)
Offline mike.
Coil Pack Failed!!
« on: 29 March 2013, 23:13 »
Just had a coil pack fail, 36K miles, car misfiring under load. Luckily two days before warranty runs out.  :smiley:
I thought VW had sorted this issue.
When I looked up the part number on ETKA it has been updated twice since 2010.
Mk6 GTI 3dr | DSG | Tornado Red | 18" Monza 2 | LED Xenons | RNS510 | Bluetooth | Smoked LED tails | Cruise | Reversing Camera | TPMS | - now sold :(
Offline Mr GTD
Re: Coil Pack Failed!!
« Reply #1 on: 30 March 2013, 09:13 »
Like you say Mike, at least it's happened within "warranty" as by the sounds of it good customers relations mean diddly scwat nower days...
Offline dereks
« Reply #2 on: 31 March 2013, 17:04 »
Mmmm. Noticed a couple of times between 70-80 a slight flutter from the engine wonder if its the same thing mines is 3 year old with 12k in for a service in a couple of weeks hopefully they find something.
« Reply #3 on: 31 March 2013, 21:38 »
Bad news and interesting.
Thankfully a warranty job.
Offline EyeballPaul
« Reply #4 on: 02 April 2013, 21:19 »
I remember the same thing started to happen to the mark 5's as i had mine done, and VW issued an under the radar recall, well they changed them if you mentioned it to them
Offline Mr GTD
« Reply #5 on: 02 April 2013, 22:29 »
How did you get on Mike...?
Offline jonesltd
  • MK7 R
« Reply #6 on: 04 April 2013, 08:59 »
I wonder if mine is failing? In mornings the coil light stays on longer than normal? 46k brought in dec 2010.
If you cant find it......Grind it
Offline mike.
« Reply #7 on: 04 April 2013, 09:07 »
Seems sorted, thanks.
Reading a bit on other forums it seems once one goes the others follow shortly after.
The general consensus is to fit a set of Audi R8 ones as they have a metal stem which dissipates the heat better
They are also cheaper than the GTI ones  :smiley:
Offline Mr GTD
« Reply #8 on: 04 April 2013, 09:09 »
Happy Days mate...
Offline Rhyso
« Reply #9 on: 04 April 2013, 10:08 »
Thats your glow plug light; it will stay on longer due to the colder temperatures to help warm the engine up
Diesels do not have coil packs  :nerd: :wink:
