Author Topic: dizi question  (Read 1471 times)
Offline yougy
dizi question
« on: 29 March 2013, 13:28 »
iv a golf mk3, if i twist the rotor arm one way should it spring back by its self, does it make any differance if it dont
thanks dave
thats fooked it
Offline tweed
Re: dizi question
« Reply #1 on: 29 March 2013, 14:48 »
The arm is on a gear and shouldn't move (not sure just using common sense) if you did move it the engine should be turning with it, and I doubt every much your that strong and that the arm is strong enough.
Yes it makes a difference!! Your ignition timing will be well out. Why did you twist it? What are you trying to do?
Offline yougy
Re: dizi question
« Reply #2 on: 29 March 2013, 14:52 »
On a lot of dizi,s u can move the rotor arm a little and it springs back but mine feels really stiff
( the rotor arm that is lol)
thats fooked it
Offline spikenipple
Re: dizi question
« Reply #3 on: 29 March 2013, 14:59 »
That's because it's pushed (and keyed) onto the distributor shaft, so it stays in the correct position.
Offline tweed
Re: dizi question
« Reply #4 on: 29 March 2013, 15:03 »
Good leave it!
Why on earth are you trying to move it? Only gonna put your timing out?
