Author Topic: 16v Brake fluid capacity.  (Read 1942 times)
Offline bretttuk
« on: 01 August 2005, 13:35 »
Hi, i am looking to find out how much brake fluid my mk2 16v holds as i will be bleeding whole system this week ..
thanks
brett
Re: 16v Brake fluid capacity.
« Reply #1 on: 02 August 2005, 14:21 »
Neither the Haynes or the Bentley can tell me, anyone else out there know? :sad:
Offline ronnie'C'
  • MKVI GTi and a MK3 VR6 (lhd)
« Reply #2 on: 02 August 2005, 21:18 »
how muck brake fluid you need depends on how well you bleed your brakes and how much air in the system their is. Normally a small bottle does the trick but if you are unsure on what you are doing then maybe get 2 bottles(check the owners manual but I think dot4) just to be on the safe side
Offline monzablue16v
« Reply #3 on: 02 August 2005, 21:42 »
Never use dot 5 silicon fluid in any car as it is proven to be dangerous think they've stopped selling it now in fact but I have heard and read of many bad things :( dot 4 is good enough, I would also recommend an Eezibleed or similar as these things make life so much easier. 1 bottle changed mine when using it get 2 though! squirt WD40 on the bleed nipples a few days before 2 dude
