Author Topic: Coil pack help  (Read 1000 times)
Offline Willows
Coil pack help
« on: 28 March 2013, 16:04 »
hey was just wondering if anyone could help me out ive got a 1.8t aum engine and currently it has 2 bolted down coil packs and the 2 in middle are not i was wondering if this will effect the system as there all not the same and if i was to upgraded them as looking to spec car out for stage 2 remap at r-tech (4h drive  :cry: hope its worth it) if so what ones should i go for thanks in advance   :whistle:
Offline Scott D
Re: Coil pack help
« Reply #1 on: 28 March 2013, 19:25 »
not sure what the latest are but i've had genuine revision R coil packs in for over two years with no problems.
might be worth contacting your local VW as coil packs are on recall
2003 1.8T GTI 180 - APR Stage I, S2000 Filter, R-Tech Supersize TIP, Bilstein B12 Suspension, 18" OZ Superleggera, Recaro Heated Leathers, US Spec Rear Lights, N249/SAI/PCV Delete
1.8T AUQ - 241bhp & 286 ft-lb
R-Tech Map, Forge FMIC, SFS Oversized TIP, Ported Manifold, Milltek Turboback non res exhaust, Forge 007p, N249 & N112 delete, SAI delete, S2000 Air Filter, Sachs clutch & Lightweight Flywheel
Offline Willows
Re: Coil pack help
« Reply #2 on: 28 March 2013, 20:01 »
My car is on 2000 plate will that still be fine ?
Offline barrym381
Re: Coil pack help
« Reply #3 on: 28 March 2013, 20:08 »
if its defo an aum then yes they had a recall  :smiley:
Offline Dalo Harkin
Re: Coil pack help
« Reply #4 on: 28 March 2013, 20:08 »
Can you post a pic ?
If you're not getting issues, I wouldn't upgrade until you do (unless you call VW and you qualify for the recall)
Offline Willows
Re: Coil pack help
« Reply #5 on: 28 March 2013, 20:34 »
Ah ok ill ring tomo after work and prob is there looks to be
Two different sorts of cool packs on it an I was told this may effect
It as they should all be the same
Offline Dalo Harkin
Re: Coil pack help
« Reply #6 on: 28 March 2013, 20:39 »
If you were getting issues with the coil packs you would know it, your car would sound like a Subaru lol
If you want to check if any of them are faulty, start the car and one at a time undo the electrical connection to each pack (1 at a time) the engine should go quieter (you'll know what I mean when you take one off) if it doesn't on one/some of them they are goosed
Offline Willows
Re: Coil pack help
« Reply #7 on: 28 March 2013, 20:41 »
Ah cheers mate ill get my bro to have alook when he fixes along line of issues with
It before a r-tech remap dn to go for stage one with 3" cat back or just wait 6months to
Get a stage 2 any ideas
Offline Dalo Harkin
Re: Coil pack help
« Reply #8 on: 28 March 2013, 20:44 »
You need a fair few mods for a stage 2 (see my Sig)
Offline Willows
Re: Coil pack help
« Reply #9 on: 28 March 2013, 20:53 »
I've pmed you don't no if you got or it even sent lol
