Author Topic: Changing the door.  (Read 1244 times)
Offline brewey
Changing the door.
« on: 28 March 2013, 13:59 »
After a car park collision dented both my passenger doors and removed my rubstrips in places i have found some replacements on the cheap. Now im going to carry out the swap myself, but wanted to see who else has done it.
So for those that have done the swap what is the easiest way to remove the door on the mark 4? The two ways I can think of doing it would be to either remove the entire door with hinge attached or remove the door leaving the hinge attached to the car.
Secondly does anybody have a guide/ advice of things to look out for when changing them over?
2000 1.8T ARZ - OEM+
Offline Mr_Orange
Re: Changing the door.
« Reply #1 on: 28 March 2013, 19:37 »
I'd suggest you leave the hinges on the car.  Access for the bolts is very restricted to do it the other way round  :wink:
You'll have to unplug the doors and this is a faff!.  The loom can either be detached from within the door (remove door card and dismantle) and left hanging ready for replacement door, or from within the car (plugs in somewhere behind the interior trim).  Depends what you've got with the replacement doors?  Are they bare or is all the gubbins included with the loom dangling?
Build thread clicky
Offline brewey
« Reply #2 on: 28 March 2013, 21:10 »
I won't know whether they are complete for sure until I pick them up tomorrow. But I'm guessing I will have to swap a lot over from my car as long as they're in a better condition than mine it's going to be worth it.
Is it a pig to get it all lined up? I remember changing a bonnet before and that was a ball ache.
Offline navmk4gti
« Reply #3 on: 29 March 2013, 17:41 »
Easy to change mate. But its a b4stard line up. Took me half hour change over doors but hours get sit perfect. Esp as i was doing both front drivers door and rear door. If your just changing one should be easy line up.
You will need another pair hands so dont do it on your own :wink:
Offline navmk4gti
« Reply #4 on: 29 March 2013, 17:45 »
Oh and forgot as mr orange has said you will have to disconect the loom. If you open the door look between.hinges there is loom going through door held by rubber gromet. Pull gromet out have a fiddle by the loom you csn unplug from there.
If your.moving all immer bits into your new door then i advise you remove.door card and all.bits first before taking door off that way you can put all inner bits on the new door :wink:
Offline brewey
« Reply #5 on: 30 March 2013, 10:34 »
It's both doors like you had to do nav. That's what I was thinking the lining up is going to be a pain. I'm thinking it might be a summer job. But I now have the doors, the front one is completly bare so I need to love everything over from my dented door. But the rear has the skin etc attached still but no window motor.
I might just swap it all over regardless as at least I know my parts work.
Do either of you guys know what tool bit you need for the hinge bolt? It looks like a tool between a triple hex and torx, but I'm sure I've seen a xzn tool states somewhere.
Offline navmk4gti
« Reply #6 on: 30 March 2013, 13:05 »
I used torx end on a rotchet mate. Not sure what mm it was now :lipsrsealed: dont need no special tool. Just get torx set.
Offline Gaz-gti
« Reply #7 on: 30 March 2013, 21:43 »
I think it's a m10 triple square bit to remove the spline bolts.
Offline Blackie20vt
« Reply #8 on: 31 March 2013, 14:45 »
Correct.
I have just changed my doors over this weekend. to remove door 6mm on the top hinge and a m10 triple for the bottom hinge.
Did it myself under an hour each door.
Offline brewey
« Reply #9 on: 31 March 2013, 16:43 »
Thanks guys. Got the doors so I'll look at changing them over at some point soon.
Need to get the Depo's on first.
