Author Topic: Oil on spark plugs/coil pack  (Read 781 times)
Offline Melvi
« on: 28 March 2013, 12:43 »
Hi,
1999, 1.8t, AGU
car has been running really badly, and cutting out on occasions, checked the spark plugs and the 1st two cylinders where covered in oil, when i removed the coil pack they were covered, leaving the spark plugs in a puddle of oil basically, removed the plugs, and they where also drenched at the end of plug ( where they ignite from)
am thinking the rocker cover gasket possibly?? but wuld like some opinions please from you guys please :D
sorry if my discribtion is like a child explaining, bit of a nob  :huh:
Offline barrym381
Re: Oil on spark plugs/coil pack
« Reply #1 on: 28 March 2013, 12:45 »
you are right in thinking rocker cover gasket  :wink:
Offline dom
  • Back in a Mk4
« Reply #2 on: 28 March 2013, 13:06 »
It'll be the valve cover gasket inside the rocker cover, you'll be best off replacing the rocker cover gasket at the same time.
Offline navmk4gti
« Reply #3 on: 28 March 2013, 13:14 »
I had same thing in the past on my agu rocker cover gasket sorted it :wink:
