Author Topic: Composition Media - Bluetooth Streaming?  (Read 9571 times)
Offline HA54SYM`
« on: 28 March 2013, 10:09 »
Hi,
Does anyone know if you can stream music via bluetooth to the standard composition media the GTi comes with, and not have to use the IPOD/IPHONE lead in the gloovebox?
Dave
94 - Roversport Tomcat Racecar
Offline Jimble
  • Moderator
Re: Composition Media - Bluetooth Streaming?
« Reply #1 on: 28 March 2013, 12:36 »
I would've thought so mate, the RCD 510 could do it so i would imagine it'd be available on the new systems.
« Last Edit: 28 March 2013, 12:39 by Jimble »
Offline HA54SYM`
« Reply #2 on: 28 March 2013, 15:15 »
Really?
My current RCD510 does not, but the Sony in my Moneo does?
I mean you don't need to have a lead connect to the phone, it works just like an air speaker?
Dave
Offline dubber36
« Reply #3 on: 28 March 2013, 15:19 »
Really?
Do you have integrated Bluetooth tho'? When you press the Media button on the RCD510, you get options at the top of the screen for CD, SD Card, Media In or Bluetooth Audio.
« Last Edit: 28 March 2013, 17:07 by dubber36 »
Offline Sootchucker
« Reply #4 on: 28 March 2013, 15:29 »
Streams perfectly to my RNS-510 in the Rocco and the RCD-510 in the Wife's Polo 6R via bluetooth - no cables required, so as stated, I would be staggered if the more modern setup in the MK7 Golf couldn't.
Obviously both cars are equipped with genuine VW bluetooth kits.
Offline Jimble
  • Moderator
« Reply #5 on: 28 March 2013, 16:18 »
Really?
Dave
Yeah you don't need the cable but as Simon said you do need a bluetooth module, if you have it though you just need to make sur "BT Audio" is enabled on the head unit.
As bluetooth is standard in the mk7 i would expect it to work.
Offline SoundillusioN
« Reply #6 on: 28 March 2013, 20:08 »
I can confirm that this can be done and very well too. I have a windows 8 phone which I can control via the touch screen.  :cool:
Also note that I have a work phone too and recently discovered I can pair my work phone for calls and personal phone for music and easily switch about for various combinations
« Last Edit: 28 March 2013, 20:11 by SoundillusioN »
Offline HA54SYM`
« Reply #7 on: 29 March 2013, 06:44 »
Thanks guys, I havn't got the bluetooth module, so I guess that explains it.
Dave
Offline Belix
« Reply #8 on: 29 March 2013, 09:24 »
thought BT was standard on all Mk7s?
Offline Jimble
  • Moderator
« Reply #9 on: 29 March 2013, 10:01 »
It is, he said it does't work on his current RCD510. :wink:
