Author Topic: Help need AGAIN please.  (Read 1335 times)
Offline Wickerdiwawa
« on: 27 March 2013, 23:26 »
Ok so I had the coolant and stat replaced today
And now the heater gauge works fine(happy days)
But after Picking her up on boost thick whitey grayie smoke
is poring out of the exhaust so I stopped
No overheating no lights on dash stinks abit.
So I let her cool down then off I went again
It happened again on boost with a bit off noise as turbo spins
So pi'sed off me just put my foot down a bit more
And it stopped smoking and boosting all fine.
Any ideas? Before I burn it.
Offline Nino
Re: Help need AGAIN please.
« Reply #1 on: 28 March 2013, 07:43 »
Did you. Hange the temp sensor as well? Also might be worth doing it mate only cost a few quid.
Also might aound stupid but have you put the stat in the correct way with the rubber o ring on the correct side?
Current - MK6 GTi Edition 35
« Reply #2 on: 28 March 2013, 08:18 »
Hi I changed the temp senser first with OE part
And my local garage done the stat and coolant.
Offline Nino
« Reply #3 on: 28 March 2013, 09:53 »
Hmmm don't sound good mate. Smoke like that would suggest water is getting in the clinders id suggest you get a compression test done mate.
« Reply #4 on: 29 March 2013, 16:38 »
Ok now I'm confused like f''k drove it again today
To my mate garage to do compression test
came back fine and boosting fine and no smoke
insight.
Offline Granta Gti
« Reply #5 on: 30 March 2013, 09:00 »
I would say your oil seals on your turbo are on the way out.
Offline Nino
« Reply #6 on: 30 March 2013, 11:48 »
insight.
Trust me thats good news means your head gasget is ok :)
