Author Topic: Wont Start....HELP PLEASE!  (Read 24885 times)
Offline xionsolaris
Re: Wont Start....HELP PLEASE!
« Reply #30 on: 01 April 2013, 10:24 »
Change that relay but u need to find out if its a idle problem i would try hold the revs all the way up to opersting temputure to see if it cuts out with holding the revs if it dosent and then u let it idle and cuts out it would be worth checking the maf sensor theres a guide on here how to do it with a multimeter so u dont have to buy a new part and hope thats ur problem its in maintainence and then diy guides but change that relay
analogue_rogue
« Reply #31 on: 02 April 2013, 16:26 »
hall sender unit on dizzy.  if you hold the centre lead from dizzy close to earth (block)  turn igmition to pos 2 and off repeatedly if it sparks at all the sender has gone short circuit.
Offline davidopresto
« Reply #32 on: 03 April 2013, 15:38 »
Right im trying to find a new hall sender, i cant find one anywhere, only a whole distributor. Any idea where i can get one? i usually rely on GSF or eurocarparts but neither of them sell them
Offline dixie180
  • Mk3 8v Gti,Mystic Blue the best colour.
« Reply #33 on: 03 April 2013, 16:16 »
Hi bud.Have you tried a new fuel pump relay 167 before you start spending money on things you don't need??
analogue_rogue
« Reply #34 on: 03 April 2013, 16:44 »
why does he need a fuel pump relay?
theres no spark. so its not a  fuelling issue?!
hall sender comes only on dizzys mate. best thing is to go to a scrappy get one and if it fixes it start saving for a new one...
Offline dixie180
« Reply #35 on: 03 April 2013, 16:52 »
Oh really???
right guys, had a play around with it today and after a few little fiddles, it started.....
i left it running and after 5/10minutes it just died. and wouldnt start again. Then after a few hours i had another go and it started again. 5/10 minutes later, it died again  :angry:
this makes me think its something to do with the engine warming up and cutting out or something along those lines?
BUT the fact that it can start and idle tells me that everything works i.e fuel pump, spark plugs and so on but something is causing it to cut out...
Extremely confusing and very stressful  :embarrassed:
« Reply #36 on: 03 April 2013, 16:53 »
fuel pump relay 167 seems to be clicking fine etc, But im getting fuel to come out on turnover so its not that, its definately electrical.
Ive been reading thousands of forums and the usual suspects that are turning up as far as im aware are:
-Oil Pressure Sensor
-Engine crank sensor
-MAF sensor
-Lambda sensor
-oxygen sensor
-hall sender
Any idea of anything to do with these?
Offline dixie180
« Reply #37 on: 03 April 2013, 17:17 »
You forgot faulty Ignition Switch. :shocked:
analogue_rogue
« Reply #38 on: 03 April 2013, 17:37 »
Your missing the shorted hall sensor! They get warm go short circuit i have had many many cars over the years with these symptoms. Its not a fuelling issue.
Did you do the test i said with the main lead on dizzy?  Did it spark when turned to pos 2 and off?
If it did that is the hall sender its the only thing that gives that symptom.
« Last Edit: 03 April 2013, 17:39 by analogue_rogue »
Offline xionsolaris
« Reply #39 on: 03 April 2013, 17:47 »
I thought a faulty hall sender wont let u rev past 5k and puts engine in limp mode
