Author Topic: under bonnet fibre stuff  (Read 1009 times)
Offline Dalo Harkin
« on: 26 March 2013, 20:09 »
I would like to remove this, but surely the bonnet would get hotter without it there and don't want the paint to get affected ( outside before anyone comments  :tongue:)
Options? Preferably without using the fast and furious reflective tin foil type stuff
Offline paultownsend
Re: under bonnet fibre stuff
« Reply #1 on: 26 March 2013, 20:44 »
I took mine off mate as it reduces under bonnet temps. No issue with paint at all
Offline Scott D
« Reply #2 on: 26 March 2013, 20:51 »
had it off for almost 3 years, not noticed any problems with paint although only wash it once a year so not likely to notice  :grin:
2003 1.8T GTI 180 - APR Stage I, S2000 Filter, R-Tech Supersize TIP, Bilstein B12 Suspension, 18" OZ Superleggera, Recaro Heated Leathers, US Spec Rear Lights, N249/SAI/PCV Delete
1.8T AUQ - 241bhp & 286 ft-lb
R-Tech Map, Forge FMIC, SFS Oversized TIP, Ported Manifold, Milltek Turboback non res exhaust, Forge 007p, N249 & N112 delete, SAI delete, S2000 Air Filter, Sachs clutch & Lightweight Flywheel
Offline Dalo Harkin
« Reply #3 on: 27 March 2013, 08:58 »
My engine bay gets very toasty with the stage 2 though.......... I would like to remove it but not at the expense of a respray
Offline Ashmond
  • Money, b!tches And Boost
« Reply #4 on: 27 March 2013, 10:23 »
dont have any under my bonnet and the paint is fine, havent had any since 2008
Offline Dalo Harkin
« Reply #5 on: 27 March 2013, 12:37 »
Off it comes then, Cheers all
Offline davemk4
« Reply #6 on: 28 March 2013, 06:53 »
I took mine off too and all is fine. Makes air filter and dv louder abit too
2001 mk4 GTI 1.8t AUM. k&n induction kit with customer heat shield, 3'' TIP, Forge 007P, Stage 1 map, N249 bypass, 3'' downpipe and decat, 2.75'' Jetex cat back non res, Koni shockers and H&R springs 35mm, dimpled and grooved disks front and back
Offline scarr89
  • Mk4 Golf, DERV FTW!
« Reply #7 on: 28 March 2013, 09:20 »
I removed mine. I think the only time it would do anything good is in winter. Sometimes I wish it was there to drown out the rattle of my diesel engine!  :embarrassed:
