Author Topic: swaping front door handles?  (Read 2295 times)
Offline Deefadog
  • Mk2 16V (November 89)
« on: 01 August 2005, 10:44 »
Can i swap my passenger front door handle for my drivers one and still use the lock, i think you have to pop out the pin and swap the levers on them, is this right?
Offline Mr Blue
Re: swaping front door handles?
« Reply #1 on: 01 August 2005, 11:14 »
Someone pass me a large hammer. Ill fix it deffa :cool:
yeh you might need to swap them over by taking the pin out :wink:
Offline Deefadog
« Reply #2 on: 01 August 2005, 11:26 »
so it can be done then?
Will the lock have to be swapped also?
Offline Mr Blue
« Reply #3 on: 01 August 2005, 11:35 »
think your ok with th lock. undo the screw on the barrel and swap the mechanism over if needed :wink:
why u swapping?
Offline Deefadog
« Reply #4 on: 01 August 2005, 11:46 »
Cheers,
the actual bit with the thread hole has actually snapped, so my handle is falling out :)
I have the chinese handles to fit, but these are a bugger and i need to fiddle about with them alot to get them right! And of course  my central locking has packed up from the alarm! :) perfect :)
I got my C0 set right and fitted the weighted hift rod (big, big fifference)!
Offline Deefadog
« Reply #5 on: 02 August 2005, 10:41 »
Managed to swap them over :) Bit of a bugger, battering those split pins out, but it worked :)
Offline Mr Blue
« Reply #6 on: 02 August 2005, 10:55 »
btw whats the shift rod like? is it a tight gear change?
Offline Deefadog
« Reply #7 on: 02 August 2005, 11:33 »
It's a bit like power steering but for the gear change!  :grin:
Just do it! Best thing i have done -  i don't get the second gear crunch an i can select first, first time everytime now with this on, much smoother also!
Offline takethefifth
« Reply #8 on: 03 August 2005, 00:56 »
Hey Deefa, had to ask as i had heard about the weighted shift rod....  Which one did you get? Sounds exactly what i need! Don't get me wrong my gear shift isn't bad but it just feels a bit light and as though i have to put it into each gear rather than just letting it flow.. :evil:
Now i have been told that i need a special Mk2 one, someone said the Mk3 standard one will sort it......  Would it be rude to ask what part was it and where did you get it?
Offline Deefadog
« Reply #9 on: 03 August 2005, 08:17 »
No rude at all  :grin:
Part No: 1HO 711 183
Price: £12.78
Yes it does just flow better, and that part is off the MK3 - but fits perfect!
Hope that helps
