Author Topic: POLISH AND PORTING THROTTLE BODY  (Read 6480 times)
Offline spikenipple
Re: POLISH AND PORTING THROTTLE BODY
« Reply #10 on: 27 March 2013, 15:34 »
If someone can provide a decent set of pictures showing before/after, I will happily port it out and polish it for you on my lathe.
Offline blueandy
Offline spikenipple
« Reply #12 on: 28 March 2013, 11:27 »
Cracking, fire us a PM then foreveryoungaus16v! If you send it my way, I'd appreciate it if you could measure the manifold port size so I can match them up, preferably with vernier calipers or something accurate  :smiley:
Offline Foreveryoungaus16v
« Reply #13 on: 28 March 2013, 12:36 »
Sent you PM my friend :smiley:
163 BHP (TSR POWER RUN)
VW BUSH
« Reply #14 on: 28 March 2013, 19:53 »
On an 8v as you can only skim out so much on the lathe before it undercuts on the top side while you still have some step at the bottom.
By the time you have clocked it true on your face plate you could have dremmeled it :smiley:
Buy some Carbide burrs (not cheap) as they will cut it very cleanly and quickly and stay sharp for years if used on ali.
Dont drop them or press too hard as they will break.
http://www.ebay.co.uk/itm/10-Piece-Tungsten-Carbide-Burr-Set-3mm-3mm-shank-10-3x3-/360623128658?_trksid=p2047675.m1850&_trkparms=aid%3D222002%26algo%3DSIC.FIT%26ao%3D1%26asc%3D11%26meid%3D6568693252580083354%26pid%3D100011%26prg%3D1005%26rk%3D5%26sd%3D160968467775%26
If your up for making new vanes (Tricky) you can take it out a bit bigger and blend the step right out on a lathe :wink:
Offline Leroy
  • Golf GTI Anniversary 16v
« Reply #15 on: 30 March 2013, 11:22 »
You could make a tidy profit doing these SpikeNipple, i want mine doing but haven't got the balls to do it myself!
Offline spikenipple
« Reply #16 on: 30 March 2013, 11:30 »
If you need yours doing too then drop me a PM. I'll probably take mine off later and measure it all up so I can produce some definitive drawings  :wink:
Offline Leroy
« Reply #17 on: 30 March 2013, 11:39 »
I'll get a spare and get back to you, cheers buddy!!!
Offline murraymint
« Reply #18 on: 30 March 2013, 12:48 »
I have a spare I wouldn't mind sending off to get done  :cool:
josh
Offline spikenipple
« Reply #19 on: 30 March 2013, 13:57 »
Drop me a PM buddy!
