Author Topic: Wasnt expecting to find this...  (Read 1489 times)
Offline Chris#101
« on: 25 March 2013, 19:11 »
Well currently changing my turbo for a recon unit, as It has suspect blown oil seals and I also have a badger 5 ported manifold to fit.
Taking my old unit off I was greeted with this  :shocked:
Money shot  :cool:
What on earth would of caused for the fins to break up/ bend? :undecided:
          2003 1.8T: R-tech Live Cutom Stage 2 remap: N249 Bypass : Forge T.I.P : Forge 007p  : Forge Actuator, yellow spring : Toyosports F.M.I.C : Toyosports C.A.I :        PCV simplified - oil catch can : 42' Draft 3" turbo back non res exhaust system : Devils own W.M.I : 231bhp & 258lbs-ft
Offline topher
  • Administrator
  • fully functioning
Re: Wasnt expecting to find this...
« Reply #1 on: 25 March 2013, 19:14 »
a bit of crap must have made its way past the filter, or it was a bit of the filter itself. I've seen way worse than that and they only made a slight whistle. Not like the 2.0TDI turbos you only need to look at those the wrong way and they make noises like a police siren!
Offline Dalo Harkin
« Reply #2 on: 25 March 2013, 19:47 »
As said FOD (foreign object damage)
That does look quite bad though  :shocked:
Offline Chris#101
« Reply #3 on: 25 March 2013, 20:56 »
And to think I had the turbo with damaged turbine off less than 6 months ago fitting the forge actuator and was in immaculate condition   :huh:
Surprised the car was still running smoothly & quietly at how bads the turbine was  :whistle:
Offline 1.8t-net
« Reply #4 on: 25 March 2013, 21:02 »
Being located at the back of the engine bay is the turbo a mother and father to get off?
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #5 on: 25 March 2013, 22:23 »
Yes lol
Offline Rhyso
« Reply #6 on: 25 March 2013, 22:38 »
Yes lol
You're a dab hand at it now though  :kiss:
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #7 on: 25 March 2013, 23:22 »
Taking apart was the easy but, I've got to put it back together yet...
Offline rio_gti
« Reply #8 on: 26 March 2013, 00:08 »
Did you notice and difference then? (Sound ect)
Also could you send me/post a few closer shots of the mani as I'm slowly porting mine at the mo
