Author Topic: bbs clearance question  (Read 5980 times)
Offline Foreveryoungaus16v
Re: bbs clearance question
« Reply #20 on: 26 March 2013, 15:07 »
Halfords :wink:
163 BHP (TSR POWER RUN)
Offline tweed
« Reply #21 on: 26 March 2013, 16:54 »
You don't need hubcentric when that small because the wheel will seat on the hub still
Offline vwwvgolf
« Reply #22 on: 26 March 2013, 18:29 »
ah okay, what bout the standard bolt?? will they be safe or shall i get some 5mm longer ones??
Offline tweed
« Reply #23 on: 26 March 2013, 18:55 »
Standard bolts are fine up to 5mm spacer. Any bigger than 5mm then but longer bolts.
Offline vwwvgolf
« Reply #24 on: 26 March 2013, 18:59 »
cheers tweed
thanks for all the info people!!
ill try get a pic up once its all sorrted
Offline tweed
« Reply #25 on: 26 March 2013, 19:21 »
No probs  :wink:
Offline nhop10
  • Mk3 GTi
« Reply #26 on: 06 April 2013, 00:32 »
i had the same issue the other day on my 8v, after a long wait getting the same bbs's refurbed and time to put them on they catch on the calipers badly so car wont move, was bemused as obviously vr6 brakes should be bigger. did you say you've solved the problem with 10mm spacers? i was thinking about getting 15mm for the fronts but wasnt sure what would be enough? just worried about rubbing on the arches, as im lowered on coilies..
Mk1 Golf 1.1, 6n Polo 16v, and now an 8v mk3 GTi
Offline vwwvgolf
« Reply #27 on: 06 April 2013, 10:03 »
yeah solved with 10mm spacers, although i am rubbing alot now and so going to have raise it up a bit to help. im only lowered 50mm at the moment.
