Author Topic: Not exactly what I had in mind...  (Read 3527 times)
Offline asboGTI
Re: Not exactly what I had in mind...
« Reply #20 on: 26 March 2013, 16:10 »
how easy is it to get the studs out as i did similar on my turbo
vw golf mk4 ARZ 1.8T pipercross panel filter, xenon headlights, JOMS coilovers, forge 007p with green spring, audi tt anti roll bar, 3inch ebay trubo back exhaust, COOKIES MONSTER STICKER(adds bhp I swear)
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #21 on: 26 March 2013, 16:16 »
If you've got some left poking out and you can get some heat on the exhaust housing (oxyacetalene is best) and a decent set of stillsons they should come out. Taking the turbo out makes it easier but it can be done in situ, just watch out for pipes etc. There's not a great deal of space so a steady hand is needed. I don't have any gas so it was easier to bring it to work
Offline asboGTI
« Reply #22 on: 26 March 2013, 16:20 »
sweet will do it eventually when i chance
Offline Scott D
« Reply #23 on: 26 March 2013, 17:11 »
ive done the same attempting to fitting a decat pipe yesterday snapped two studs, got them out but the thread is damaged.
had to drop it in a garage today and cancel the trip to r-tech tomorrow  :angry:
2003 1.8T GTI 180 - APR Stage I, S2000 Filter, R-Tech Supersize TIP, Bilstein B12 Suspension, 18" OZ Superleggera, Recaro Heated Leathers, US Spec Rear Lights, N249/SAI/PCV Delete
1.8T AUQ - 241bhp & 286 ft-lb
R-Tech Map, Forge FMIC, SFS Oversized TIP, Ported Manifold, Milltek Turboback non res exhaust, Forge 007p, N249 & N112 delete, SAI delete, S2000 Air Filter, Sachs clutch & Lightweight Flywheel
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #24 on: 26 March 2013, 17:23 »
Ah bugger. They helicoiling it for you?
At least I'm not alone lol
Offline Scott D
« Reply #25 on: 26 March 2013, 17:36 »
Yeah will be helicoiling it
God knows what had been used to previously tighten them up and downpipe didn't seem like it had been aligned correctly before tightening - all holes was off to the left by 4-5mm.
Should of been an easy half hr job a decat pipe  :grin:
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #26 on: 26 March 2013, 17:57 »
Yep exactly what I said
Offline rio_gti
« Reply #27 on: 26 March 2013, 22:25 »
I snapped one gettin mine off but there was enough to get a stud removal to on it
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #28 on: 26 March 2013, 22:32 »
Turbo is in with oil and water lines connected, TIP is in place. Would have got further but some idiot left the manifold at home... Oh and I had to finish off fitting my short shift lol
Managed to mangle one of the threads on the studs too, fixed with my die kit though
Offline Dave_IOW
« Reply #29 on: 26 March 2013, 23:29 »
Manifold :rolleyes:
What short shift?
Project: Mk2 20vT trackslag
Daily: Mk2 GTI typ19
