Golf mk2
ignition
Topic: ignition (Read 2709 times)
Rain
forum irregular
ignition
31 July 2005, 22:16 »
can anyone tell me if the later mk2's and earlier mk2's igniition barrels etc are compatable with each other??
mrwotto
Guest
Re: ignition
31 July 2005, 22:20 »
Think its just the switch that is different mate
kniterider
had most, sold most and often buy more!
Re: ignition
31 July 2005, 22:23 »
there diffo mate the later ones (hazard switch on top of colum) is diffo to the earlier ones so its not a swap, you can change but it has to be a few other bits as well wiring,later mfa wiper stalk, ignition barrel and some other bits
Gaz
Rain
forum irregular
Re: ignition
31 July 2005, 22:26 »
cheers gaz was only asking cause i really dont like sitting with ignition on full all the time just for the radio and seeing as i got most the dash out lol i thought id wire it up properly nm ill just add a switch so i can power it up when ignition is off
cheers
kniterider
Re: ignition
31 July 2005, 22:30 »
there is an accessory feed from the ignition barrel but with out looking at a wiring diagram i cant tell you what colour!!! and seen as me manuals are in a garage and i cant move..........
lol
Rain
forum irregular
Re: ignition
31 July 2005, 22:34 »
hmm well there is only like 4 wires so im sure i can find it ill use a multimeter tomorrow see if i cant find it oh i found the toad alarm by the way lol no clue how they got it in the box was huge about half a foot wide lol
Agreeable Slick
Global Moderator
Serious forum addict
Unit
Re: ignition
Reply #6 on:
01 August 2005, 02:29 »
if you mean the remote cable from the barrel i think it should be blue.
I made this : ->
https://www.golfgtiforum.co.uk/index.php?topic=30416.0
workhorse '90 8v
Here all the time
Re: ignition
Reply #7 on:
01 August 2005, 07:09 »
your stereo should have a permanent live wire and a live wire
wire these two together (as a permanent live) and the stereo will work with the ignition off..
kniterider
Re: ignition
Reply #8 on:
01 August 2005, 09:13 »
aye they do......^^^^^
i like to know that when me cars 'off' me stereo is 'off' too!!! lol, otherwise the amount of times my mrs would ring up 'the car wont start' because of leaving the stereo in would be unreal!!
Rain
forum irregular
Re: ignition
Reply #9 on:
01 August 2005, 10:53 »
i had the problem of the coil burning out cause it had been on for an hour without the car starting and didnt like it one bit :S
Golf mk2
ignition
