Author Topic: sound actuator  (Read 6902 times)
Offline golfgti5
sound actuator
« on: 24 March 2013, 12:06 »
Hello,
in the Netherlands the new Golf VII GTi has a sound actuator wich can be turned on and off, does anyone knows how that should be done?
GTI Mk7 DSG Candy White, 19" Santiagos, Discover Media, xenon, Executive Package, ACC, PDC, Park Assist, Alarm+......
Offline topher
  • Administrator
  • fully functioning
Re: sound actuator
« Reply #1 on: 24 March 2013, 13:27 »
I imagine it'll be an adaptation channel or long coding edit, possibly accessible through the MFD. Won't be able to say for sure until I see one!
Offline joe6
Re: sound actuator
« Reply #2 on: 24 March 2013, 19:11 »
There is a sound generator in the Scirroco 170 diesel but it does not appear to be 'switchable'.
I quote - 'The sound device doesn't show up in Vcds/vagcomm, but it is connected to the can-bus.
The only way to turn it off is to disconnect the transducer.
It's definitely an artificial noise - there's a noise generator/control unit, and the transducer/speaker device.'
In the ROC it is under the plastic trim under the wipers.
Cannot understand why VW want to make a car noisier! Best of luck turning it off.
« Last Edit: 24 March 2013, 19:25 by joe6 »
Offline Jimble
  • Moderator
Re: sound actuator
« Reply #3 on: 24 March 2013, 20:13 »
How do you know you want to turn it off? Nobody has heard it yet! ???
Offline golfgti5
Re: sound actuator
« Reply #4 on: 24 March 2013, 20:16 »
I think the GTi is to still, so the louder the better
Offline monkeyhanger
Re: sound actuator
« Reply #5 on: 01 April 2013, 14:56 »
The one in my current Roc (170TDI) is a big improvement over the standard engine noise of teh 140. Of course I know it is artificial, but even so it sounds mean even if externally it sounds just like a 140. I'm hoping that my new MK7 GTD will have one!
Offline Mr GTD
Re: sound actuator
« Reply #6 on: 01 April 2013, 16:10 »
The one in my 6 makes it sound a lot better than a std diesel....
