Author Topic: mk4 golf 18t chain tensioner  (Read 1946 times)
Offline rs2000
« on: 23 March 2013, 13:50 »
hi i have a mk4 golf 18t the car starts and ticks over fine but when it gets to 90 degrees the chain starts hitting the rocket cover and it sounds like a desil i changed the chain and tensioner but nothing please can somone help
Offline beppe2672
Re: mk4 golf 18t chain tensioner
« Reply #1 on: 23 March 2013, 19:21 »
Did you change the gasket too? And did you put any sealant on it?
« Last Edit: 23 March 2013, 19:30 by beppe2672 »
1999 1.8t AGU, KNN Panel filter, Smoothed air box, Custom CAI, Forge 007 dv, REVO stage 1, 3" eBay TBE. Audi TT quickrack.
To come - A DIY hybrid K03 and a whole lot of supporting mods!
Offline rs2000
« Reply #2 on: 24 March 2013, 09:26 »
yeah but new gasket on it and a bit of sealent but still the same only when the engine gets hot
Offline beppe2672
« Reply #3 on: 24 March 2013, 17:15 »
Bit of a long shot but what oil are you using?
Offline rs2000
« Reply #4 on: 25 March 2013, 12:26 »
im useing 15-40 from vw
Offline dom
  • Back in a Mk4
« Reply #5 on: 25 March 2013, 17:45 »
Checked the level recently?
Offline rs2000
« Reply #6 on: 25 March 2013, 19:03 »
yeah theres plenty of oil its baffeling me  :sad:
Offline topher
  • Administrator
  • fully functioning
« Reply #7 on: 25 March 2013, 19:06 »
can you see marks on the underside of the cam cover where its been hitting? A rattling flywheel is often mistaken for chain noise, particularly when it gets warm
Offline rs2000
« Reply #8 on: 26 March 2013, 09:14 »
yeah there are marks under the cover where the chains been hitting it ill try that wheel thanks
Offline beppe2672
« Reply #9 on: 26 March 2013, 23:39 »
Done a bit more research into this as its baffling me! What's your engine code and the part number for the tensioner you fitted? There's 2 different tensioners for non-vvt and vvt engines. Also found out this could be a symptom of a worn oil pump or blocked pick up pipe.
