Author Topic: mk2 8v problems  (Read 1909 times)
Offline ritmo
mk2 8v problems
« on: 22 March 2013, 14:10 »
my car is a 90spec 8v digi and has started to cut out when driving!! can be at any speed!
when it cuts out I can't restart it but if you leave it for a couple of mins it starts again :laugh:
its been doing this on and off for the last week or so however its getting worse and more frequent.
any ideas what this could be, I'm guessing fuel? possible filter? fuel pump(it does make a noise when ignition on).
Offline X4MGS
  • VAG Parts SNOB!!!
Re: mk2 8v problems
« Reply #1 on: 22 March 2013, 14:23 »
Have you tried resetting the ecu?
Would suggest new blue temp sender, plugs, rotar arm, test HT leads etc...
For More Info Click To See;
analogue_rogue
Re: mk2 8v problems
« Reply #2 on: 23 March 2013, 11:49 »
When it cuts out, pull king lead off dizzy and hold 1mm from annearth. Turn ignition to pos two and back (to energise te coil) does it spark? If it does ten its hall sender failing when warm
Offline ritmo
Re: mk2 8v problems
« Reply #3 on: 23 March 2013, 13:50 »
how do you reset the ecu ?
what if I'm getting no spark will it be the coil?
driving the car just now so we will see if it does it today!! ahhhh!
the joys of owning a mk2 well 23 year old car
 :smiley:
Offline X4MGS
  • VAG Parts SNOB!!!
Offline rob.043
Re: mk2 8v problems
« Reply #5 on: 24 March 2013, 21:57 »
My similar experience was due to failing fuel pumps. I replaced both in the end. I noticed the car only cut out when the fuel level was low as the pump's had to work harder. I changed the in tank pump first, but problem persisted to the main pump was done too
« Last Edit: 25 March 2013, 12:53 by rob.043 »
