Author Topic: Debadge Rear  (Read 1661 times)
Offline capoot
  • Mk1 Skoda Octavia VRS
Debadge Rear
« on: 31 July 2005, 19:48 »
If i take the Golf And Ryder bits off, will it leave holes or is it a heat gun/hair dryer  jobbie?
Offline pegasus
Re: Debadge Rear
« Reply #1 on: 31 July 2005, 19:55 »
U will find holes under the 'golf' badge, not sure about the 'ryder' bit
1.8 20VT GTI
Offline capoot
Re: Debadge Rear
« Reply #2 on: 31 July 2005, 19:57 »
right mmmm  :undecided:
Offline [han]
  • Graphic Designer for Haribo
Re: Debadge Rear
« Reply #3 on: 31 July 2005, 19:57 »
got holes under the one at the yard.... was just two i think... pulled badge off to see what mine would be like if i took the driver badge off the back of mine... (got a spare gti and driver at the yard which i have stipped down to what we can) they're off to scrappy sometime this week, so if its stil there tomorrow i can confirm - but im sure there were holes under the driver badge!!!
han :smile:
Offline pegasus
Re: Debadge Rear
« Reply #4 on: 31 July 2005, 20:00 »
Hannah, dont suppose this 'spare gti' has a spare 'big bumper' does it?
1.8 20VT GTI
Offline [han]
Re: Debadge Rear
« Reply #5 on: 31 July 2005, 20:03 »
it's at my uncles yard, and my cousins being the twts they are, stripped it of big bumpers.. and all bits i wanted.. fookers! lol.. but at teh time i didn't have the golf so i stripped whats left tbh - sorry hunny! no such luck! xxx
Offline pegasus
Re: Debadge Rear
« Reply #6 on: 31 July 2005, 20:38 »
no worries  :wink:
1.8 20VT GTI
Offline theviper
Re: Debadge Rear
« Reply #7 on: 31 July 2005, 20:41 »
i was told i would have holes under mind but do not if you look inside the car were the badge is you will see if it has some lugs which is were the badge will be if you dont see them you may be lucky like me  :smiley:
pete :evil:
Offline VWDino
  • MkII 1.6 Driver. GTi cam, K&N .....
Re: Debadge Rear
« Reply #8 on: 31 July 2005, 21:26 »
Mine had the square "Driver" badge (older?) on mine. It was just glued on so a hot air gun and ten minutes was all that was required. I would have a guess that yours would be the same. As theviper says lugs on the inside = holes, no lugs = no holes  :smiley:
Offline Agreeable Slick
  • Unit
Re: Debadge Rear
« Reply #9 on: 01 August 2005, 02:33 »
older golfs seem to have the lugged "golf" badge, and the driver/ryder badge is generally bonded onto the body. If you are planning on filling them and painting them over you will need to take a rounded hammer to the holes that are left, so you dish them, and then sand them down using a rough grade of paper, I.E> 120 and press the filler through the holes and smooth it off from the front and behind so it has a extra grip on the panel.
Don't forget to build it up slowley and prime it all properly before painting, otherwise the filler will crack the paint and break its seal.
