Golf mk4
Wazzzer
Ticking/ clicking noise when in boost.
Topic: Ticking/ clicking noise when in boost. (Read 870 times)
Scott-R
GoT BoosT!
22 March 2013, 07:18 »
Lately been getting a ticking/ clicking noise when in boost. If I slowly go put the foot down it doesn't do it only if I plant it and it spools up fast.
Injectors on there way out?
Golf GTI ... What else would you have?
Dalo Harkin
Re: Ticking/ clicking noise when in boost.
22 March 2013, 08:35 »
boost gauge fitted? with 'no buzz' t piece?
ARZ K03s, Oettinger Side Skirts, R32 front, Carbon stage 2, Forge 007p (yellow spring), Forge Actuator (yellow spring), Pipercross panel filter with DSG parts, N249 and N112 deleted, SAI deleted, Carbon canister deleted, Rear wiper deleted, Long Life turbo back custom exhaust with 200 cell sports cat, VR6/G60 clutch kit, Creation Motorsport TIP, Catch can, 'Wellycooler', K04 charge pipe, S3 ported inlet manifold - looks pretty standard on the outside though
Scott-R
GoT BoosT!
22 March 2013, 09:02 »
I have a bad feeling about my boost gauge as it is because a noise comes from it when in boost like its leaking air.
Dalo Harkin
22 March 2013, 09:28 »
I'd be making sure the piping is ok and tight, if you don't have a proper T piece, get one as they make a horrific noise without one
weed1993
Just got here
23 March 2013, 12:08 »
i had that noise and it was my lambda sensor had broken up
davemk4
23 March 2013, 17:54 »
My t piece was a cheapo one and mine clicks too
2001 mk4 GTI 1.8t AUM. k&n induction kit with customer heat shield, 3'' TIP, Forge 007P, Stage 1 map, N249 bypass, 3'' downpipe and decat, 2.75'' Jetex cat back non res, Koni shockers and H&R springs 35mm, dimpled and grooved disks front and back
Scott-R
GoT BoosT!
Reply #6 on:
23 March 2013, 18:02 »
My lambda sensor is actually off thread so it's not sitting right just waiting on getting a new one and gonna sort it, could be that!
Had a look at t-piece and it looks to be quite well on!
Golf mk4
Wazzzer
