Author Topic: Replacement Clutch-MkII 1600  (Read 1032 times)
Offline Whysub
« on: 31 July 2005, 19:14 »
Mine has started to slip under load, so needs changing.
How much should this cost? Anyone recommend someone/somewhere in the essex area?
Ta muchly.
Offline rowlers
  • I'm back - MK7 GTI
Re: Replacement Clutch-MkII 1600
« Reply #1 on: 31 July 2005, 19:18 »
clutch parts are fairly cheap £60 - £100 depending on what you want, the labour is usually expensive though.
I've just had a Gen VW clutch fitted to my 16v, the clutch was £80 or so, but the labour came to about £150.
If you know a mechanic with the right  gear you could get it done cheaper.
