Author Topic: Golf Mk4 Cluster replacement  (Read 2943 times)
Offline rogers5uk
« on: 21 March 2013, 10:48 »
Hello,
Really need some help with this. My VW Golf MK4 TDI 1998 developed a problem where the speedo stopped working all together and the fuel gauge wobbles when entering a bend etc. I have had the gear stick sensor replaced and it still does it. A garage has ran a full diagnostics also and everything came up in order.
The rules have now changed as of yesterday for an MOT that now means you must have a working speedo hence why I am now in a panic to get it fixed as its due in April.
One thing I have not done is replace the cluster unit. Now I have seen some vids and looks fairly straight forward to do but I am concerned as I have heard from a garage that the immobiliser has to be reset so I may not be able to do it my self. does anyone know if this is the case or if I could replace the cluster unit my self with no issues??
thanks so much for your help.
Offline scarr89
  • Mk4 Golf, DERV FTW!
Re: Golf Mk4 Cluster replacement
« Reply #1 on: 21 March 2013, 12:59 »
Pretty sure you will require VAGCOM to code in the new cluster...
http://www.golfgtiforum.co.uk/index.php?board=73.0 - Take a look here, loads of info on coding and clusters.
Offline EsSeX dAn
« Reply #2 on: 21 March 2013, 18:19 »
youll want vag tacho i think to pair it to the ecu and key. then youll want the milage adjusting to the cars milage too, also done via vag tacho
i think i love you.....
Offline topher
  • Administrator
  • fully functioning
« Reply #3 on: 24 March 2013, 21:18 »
gear stick sensor??
most common cause of failed speedo in a mk4 is the wires coming from the speedo sensor on the gearbox, follow them along the top of the gearbox and they rub through/break. You'll need to take the battery tray out to see it properly
