Golf mk2
mk2 fuel guage inop
Topic: mk2 fuel guage inop (Read 1323 times)
awallis
mk2 fuel guage inop
20 March 2013, 18:07 »
hi i own a 16v mk2 golf, since ive brought the car the fuel guage hasnt worked, ive checked fuses and put some volts to the back of the speedo meter terminals on the fuel guage, that works fine.
other things i should check for?
Gambit
Forum addict
Re: mk2 fuel guage inop
20 March 2013, 18:18 »
the fuel guage float sender unit in the tank? easy enough to remove via boot
awallis
21 March 2013, 00:16 »
thanks, ill have a look at that tomorrow. Can get to it via the boot?
Gambit
Forum addict
21 March 2013, 11:07 »
yep, lift the carpet and you'll see a black plastic circular cover held on with screws. remove that then you've got access to fuel tank sender unit and intank lift pump. the plastic screw housing on the tank itself is usually pretty tight, use a wooden drift & hammer to release it
Golf mk2
mk2 fuel guage inop
