Author Topic: HELP. Car revving in neutral randomly  (Read 2826 times)
Offline KennyGTI
« on: 17 March 2013, 19:21 »
Took my car out today to the shops. When getting into a car space I put the car into neutral and the revs started going up to 1400 rpm then dropping off to 900 rpm. Car would then feel if it was about to stall and run really rough before going back to 1400 rpm. Took it up the bypass and car felt fine boosting etc but maybe just not quite as quick as usual.
Once back home the revs were still doing the same then the engine management light came on.
Vag com results:
Address 01: Engine (CDL)       Labels: 06F-907-115-CDL.clb
   Part No SW: 1K8 907 115 F    HW: 8P0 907 115 B
   Component: 2.0l R4/4V TFSI     0040
   Revision: 5BH21---    Serial number:
   Coding: 0403000C180F0060
   Shop #: WSC 78132 024 468710
   VCID: 3147D9AFA8226A909E2
1 Fault Found:
001287 - Idle Control System RPM
               P0507 - 001 - Higher than Expected. - MIL ON
             Freeze Frame:
                    Fault Status: 11100001
                    Fault Priority: 2
                    Fault Frequency: 1
                    Mileage: 7445 km
                    Time Indication: 0
                    Date: 2008.14.08
                    Time: 14:41:42
             Freeze Frame:
                    RPM: 1212 /min
                    Load: 19.2 %
                    Speed: 0.0 km/h
                    Temperature: 60.0°C
                    Temperature: 8.0°C
                    Absolute Pres.: 980.0 mbar
                    Voltage: 14.478 V
What are people's thoughts? Anyone experienced this or heard of it.
Maybe the PCV valve? When I take out my dip stick I can feel a vacuum when I put my finger over it.
Some videos:
APR Stage 2+
Offline ajmoir36
Re: HELP. Car revving in neutral randomly
« Reply #1 on: 17 March 2013, 20:44 »
Doesnt sound good.
Diagonally parked in a parallel universe.
On Order: Mk8 R, Pure White, Reversing Camera, Harmon Kardon, Heated seats all round.
Gone: Mk7.5 R, 5dr, DSG, Deep Pearl Black, 18” Cadiz, Nav, Winter Pack, Keyless, Dynaudio and Reversing camera.
Gone: Mk7 R, 5dr, DSG, Limestone Grey, 19" Pretoria's, Nav Pro, DCC, Winter Pack, Keyless, Mobile Prep and Reversing Camera.
Gone: Mk6 GTD, 5dr, Manual, Tornado Red, 18" Vancouvers, RCD510 + Dynaudio, heated seats.
Offline KennyGTI
« Reply #2 on: 18 March 2013, 10:45 »
I know  :cry:
Sounds like I need to replace this PCV Valve. Going to order an upgraded one, no point putting in an OEM one again.
BSH do one or Forge Catch Can.
APR Stage 2+
