Author Topic: totally confused mapped or not ??  (Read 1808 times)
Offline wolfie1981
« on: 17 March 2013, 14:31 »
hi guys bought my second 1.8t about a months ago its a 2000 agu.
the guy I bought it from had the car for 3 years full dealer history 2 owners  before him so anyway.
over the last couple of weeks I have bought forge 007p and spring kit, newsouth boost gauge, piller pod miltek system +decat.
today I fitted the forge dv with the green spring , and my newsouth gauge. upon startup the gauge reads 20 vac my last 1.8t  sat at 24 is this ok at 20??
but the biggest surprise was when I took it out for a spin it boosts and holds at 18psi does this sound like its been mapped??? I have changed the dv spring to the yellow now just in case
the car does pull really well but don't seem as powerful as my old 1.8t
so guys do you think she has been mapped???? or could there be a fault with the gauge or something like that.
if it has been mapped saves me some money for other mods  :wink:
also miltek not fitted yet!
Offline davemk4
Re: totally confused mapped or not ??
« Reply #1 on: 17 March 2013, 15:13 »
Stock pressure is not 18psi. Mine is stage 1 mapped and holds around 12- 14psi if yours 18psi then the car would be rapid!
2001 mk4 GTI 1.8t AUM. k&n induction kit with customer heat shield, 3'' TIP, Forge 007P, Stage 1 map, N249 bypass, 3'' downpipe and decat, 2.75'' Jetex cat back non res, Koni shockers and H&R springs 35mm, dimpled and grooved disks front and back
Offline wolfie1981
« Reply #2 on: 17 March 2013, 15:17 »
I know stock is around 6/7psi as my old 1.8t before a map was like this but after a remap she held around 18psi
Offline rio_gti
« Reply #3 on: 17 March 2013, 15:38 »
Waste gate tampered with??
Offline wolfie1981
« Reply #4 on: 17 March 2013, 15:55 »
could it just have been mapped???  does 18psi seem high ?? my last 1.8t after a remap held 18psi peak just like this one
Offline Chris.
« Reply #5 on: 17 March 2013, 16:34 »
Sounds mapped to me.
If it pins you in seat to near redline.....chances are its mapped.
Click For Build Thread
Offline wolfie1981
Re: totally confused mapped or not ?? UPDATE!!
« Reply #6 on: 17 March 2013, 16:39 »
UPDATE!!! after going out again on a open road the boost peaks at 18psi and holds at 15/16psi sound rite for a remap??
« Reply #7 on: 17 March 2013, 17:03 »
Yep, about the same as my 1.8t Octavia vRS
Offline stfc_gti
« Reply #8 on: 17 March 2013, 19:04 »
the only true way to find out would be to put it on a set of rollers
2002 1.8T GTI AUM, Standard (not for much longer)
Offline turbokid23
« Reply #9 on: 17 March 2013, 19:14 »
Mine runs 7psi witch is 0.5bar as mine standerd at the min
