Author Topic: clutch and gearbox problem  (Read 2343 times)
Offline blairyboy75
« on: 17 March 2013, 12:40 »
Hi folks came out to my car this morning drove for about four miles with no problems came back to the car couple hours later and struggles to go into gear . Its recently had a new clutch and clutch cable . Any info would be much appriciated
Gavv8
Re: clutch and gearbox problem
« Reply #1 on: 17 March 2013, 12:45 »
Is it crunching or is the gearchange just really stiff?
Offline blairyboy75
« Reply #2 on: 17 March 2013, 12:48 »
Crunches in reverse other gears are just really stiff
Gavv8
« Reply #3 on: 17 March 2013, 12:54 »
Sounds like the linkage has gone wonky, the nylon ball at the base of the shifter is a common problem which causes these symptoms, also orange bush that the shift rod passes through at the front of the shift tower wears out causing gearchange problems.
As you've had work done on the box it might be worth having a good look at the linkage between the box and the shift tower to make sure something hasn't come loose.
Offline blairyboy75
« Reply #4 on: 17 March 2013, 12:58 »
So its common for it to just go like that as its been fine up till this morning
Gavv8
« Reply #5 on: 17 March 2013, 13:02 »
Mine needs a new nylon ball and it'll be fine for days then just go all stiff and notchy, the parts to repair it are dirt cheap its just a bit of a ballache to change as you need to drop out the catalyst and heat shield so you can drop the shift tower low enough to get the shift change rod over the top of the gearstick and thus remove/replace the nylon ball, also to replace the orange bush... i'm waiting for a nice day to do mine.
« Last Edit: 17 March 2013, 13:04 by Gavv8 »
Offline blairyboy75
« Reply #6 on: 17 March 2013, 13:06 »
This might be a long shot but one of the clamps of the exhaust is round the wrong way and vibrates sometime and you can feel it through the gear stick could that have something to do with it
Gavv8
« Reply #7 on: 17 March 2013, 13:10 »
That might be just because its making contact with the underside of the car, i don't think there are any clamps near the linkage.
Offline sharki786
  • GOT BOOST??
« Reply #8 on: 05 May 2013, 08:53 »
Where did you get the nylon bush from? As i went to tps yesterday and it comes complete with the metal L shape rod and i dont want to pay 50 for that
*****MK3 Anniversary*****
*****MK4 GTI T*****
Gavv8
« Reply #9 on: 05 May 2013, 21:39 »
GSF do the nylon ball kit for about nine quid.
