Author Topic: helppppppppppppppppppppppppppppppppppppppppppppppppppppp  (Read 2867 times)
Offline col-mk3
car cut'sout when it wants! vag comsaid my crank sensor replaced it twice first 5 month ok starts doing it again plug into vag com crank sensor again so replaced now lasted 2 week cut out again!
someone said something about on the brakes there cut out thing?
it's 2litre 8v gti p reg any help gratefull because it's starting to piss me right off
Offline tweed
Re: helppppppppppppppppppppppppppppppppppppppppppppppppppppp
« Reply #1 on: 17 March 2013, 11:10 »
Check the wiring to sensor
Offline dixie180
  • Mk3 8v Gti,Mystic Blue the best colour.
« Reply #2 on: 17 March 2013, 17:31 »
Need to replace with genuine VW crank sensor.Try fuel pump relay 167 and ecu relay 30,cus they can also cause cut outs.I know cus i've been there. :angry:
Offline dixie180
« Reply #3 on: 18 March 2013, 08:14 »
col-mk3,i take it you deleted the old fault codes with the VagCom before you re-scanned?.
Offline boneybradley
  • Back in a Mk3...
« Reply #4 on: 18 March 2013, 09:28 »
as said above, replacing the crank sensor dosen't always work as the wiring harness dry's out/splits and then arc's. this gives the same faults as a dicky crank sensor
replace them wires first and see if it fixes it
Offline col-mk3
« Reply #5 on: 19 March 2013, 12:15 »
thank's il get the mechnic check all this was told crank sensor's aint any different to the genuine one's by someone who work's at vw
Offline col-mk3
« Reply #6 on: 19 March 2013, 12:17 »
yeah done that lol
Offline col-mk3
« Reply #7 on: 25 March 2013, 15:12 »
howmuch would be looking at for another wireing harness?
Offline col-mk3
« Reply #8 on: 27 March 2013, 09:07 »
  • Back in a Mk3...
« Reply #9 on: 27 March 2013, 09:39 »
best call vw and be sitting down...
Most people make there own (it's only a few wires into a connector although they do need to be heat shrinked) or contact your local auto electrician as they should knock one up for only a few ££ (well cheaper than vw)
