Author Topic: Water pump question  (Read 2221 times)
Offline AndyG
Water pump question
« on: 16 March 2013, 17:09 »
Just a bit of advice really.Not our GTI but our other golf it's a mk6 1.4.Anyway I've noticed a bit of fluid on the driveway but can't see any obvious leaks although the coolant water was below the low level.Ive noticed that on here the water pump is often mentioned.What goes wrong with them do they seize up or do they just leak?
Golf 7R,DSG,5 door White,leather,rear camera.
Offline Neil gti
Re: Water pump question
« Reply #1 on: 17 March 2013, 09:36 »
When mine started to go the only thing I noticed was a small pool of coolant on the garage floor, no obvious signs of we're it was leaking from
Mk6 Gti Gone but not forgtten
Loving the 7R
Offline AndyG
« Reply #2 on: 17 March 2013, 10:56 »
Thanks for the reply,possibly water pump on way out,will keep my eye on water level.We are out of warranty now,bugger.
Offline Neil gti
« Reply #3 on: 17 March 2013, 11:50 »
If you have had all your servicing done at the dealers, they may do it on a goodwill basis as it is a known fault, all depends on the dealers
Loving the 7R
Offline AndyG
« Reply #4 on: 17 March 2013, 12:18 »
The main dealer does all work on both our cars so I will try.
Offline Neil gti
« Reply #5 on: 17 March 2013, 12:32 »
In that case I would really push for them to do under goodwill/warranty  :smiley:
Loving the 7R
