Author Topic: Codes 16795 and 17705 still :(  (Read 845 times)
Offline jambouk
« on: 16 March 2013, 10:14 »
I've been having these codes for over two years. A non-VW garage has replaced some pipes, replaced the secondary air pump, cleaned the throttle body.... The car still sounds like a jet engine when I start up and turn the engine off and often when I'm at traffic lights (it might sound like it when I'm driving too, but I just can't hear it). I think it's started to knock the fuel consumption too and it's annoying me.
Is it time to take it to a VW garage? Will they actually be able to fix it?
Thanks for any help.
James
(very non-technically minded)
Nottingham
Offline HJGTI
Re: Codes 16795 and 17705 still :(
« Reply #1 on: 16 March 2013, 10:46 »
Have you used the vcds m8 using the vagcom lead ??
Offline jambouk
« Reply #2 on: 16 March 2013, 10:50 »
I have a code reader off ebay, an orange box, it wasn't expensive. The garage has used a better code reader and they get the same codes, but the codes have another name, but the underlying error message is the same.
James
Offline jimmyGIT
« Reply #3 on: 16 March 2013, 14:49 »
My 17705 was a few loose jubilee clips around dv area,Worth havin a quick check,making sure there all nice and tight.Check over the hoses at same time,you might get lucky!!all the best.
Offline jimmyGIT
« Reply #4 on: 16 March 2013, 14:53 »
Sorry forgot about the 16795.Must still be leaaking down at the pump or wiring.Those rivots are useless.Mines the same needs doing badly,sounded like a train so just pulled connector off.get the code up then just reset it.UMMM LAZY me!!!!!!!! search for sai repair,you will see all the pics.
