Author Topic: how to get sat nav an bluetooth working  (Read 2883 times)
Offline GJSEB79
« on: 14 March 2013, 22:26 »
hi guys just picked my son's mk5 golf its a mk5 1.6 edition 30 replica  its got a vw sat nav system it has bluetooth an sat nav but for some reason can't get either off then to work is there something you need to do or buy to get them working cheers Gordon
Offline Rhyso
Re: how to get sat nav an bluetooth working
« Reply #1 on: 15 March 2013, 07:04 »
Has he got the disc loaded in the unit?
For bluetooth, turn the ignition on whilst stationary, set your phone to search for new devices and pair once found. Think the code is 1234 or 1111
Offline Jimble
« Reply #2 on: 15 March 2013, 11:30 »
Has it definatley got the bluetooth module fitted? If not then the phone button won't work.
Offline GJSEB79
« Reply #3 on: 15 March 2013, 19:16 »
hi guys no haven't got a disc for it that what I need can any one point in right direction for one and how do you no if it blue tooth them the model is rns510 its got bt audio symbol but you can't press it it not highlighted if you no what i mean
Offline Rhyso
« Reply #4 on: 15 March 2013, 20:12 »
VW or classifieds on forums for the disc
Follow my instructions that i posted to find out if its fitted with bluetooth; it will be obvious whats its called if you find it
Offline Jimble
« Reply #5 on: 16 March 2013, 10:57 »
If you press the "phone" button on the head unit and you get the screen for the phone then it's fitted, if all it does is mute the sound then it's not.
Offline GJSEB79
« Reply #6 on: 16 March 2013, 16:23 »
Thanks jimble pressed button and it just mmute
the radio so it not ffitted  so  how  do  I  fit  blue tooth them  what  is nneed
Offline GJSEB79
« Reply #7 on: 16 March 2013, 19:41 »
right guys tried to put a dvd tonight and won't even play that does any one no what is wrong with it
Offline Jimble
« Reply #8 on: 17 March 2013, 15:10 »
The bluetooth kits are available on ebay and it's pretty straight forward although a bit fidly to fit, the below link is for a mk6 but i imagine it's fairly similar in the 5, Darren fitted mine (mortygt140 on the mk5 forum)
[font=.HelveticaNeueUI]http://www.golfgtiforum.co.uk/index.php?topic=151928[/font]
[font=.helveticaneueui]Is the head unit definately an RNS and not an RCD? Has it got the button for Nav?[/font]
Offline GJSEB79
« Reply #9 on: 17 March 2013, 19:28 »
I don't think it does its says media setup phone dab I don't think there is a button that says nav on it mate
