Author Topic: Problem with passenger door ??  (Read 1443 times)
Offline HJGTI
« on: 14 March 2013, 14:21 »
Hey all on my drivers side when I open the door all the interior lights come on and off when I close the door but when I open the passengers door the lights dnt come on at all ?? It's a 3dr , could it be something really simple ?
Any help would be appreciated  :smiley:
Offline beppe2672
Re: Problem with passenger door ??
« Reply #1 on: 14 March 2013, 17:34 »
It's probably the door module, the soldered joints on the pcb inside crack.
1999 1.8t AGU, KNN Panel filter, Smoothed air box, Custom CAI, Forge 007 dv, REVO stage 1, 3" eBay TBE. Audi TT quickrack.
To come - A DIY hybrid K03 and a whole lot of supporting mods!
Offline dom
  • Back in a Mk4
« Reply #2 on: 14 March 2013, 17:58 »
Almost certainly the door module
Offline HJGTI
« Reply #3 on: 14 March 2013, 21:06 »
Where can I get a door module from ??
Expensive ??
Offline dom
  • Back in a Mk4
« Reply #4 on: 14 March 2013, 23:26 »
I'd look in the breaking section on here, alternatively eBay.
Offline beppe2672
« Reply #5 on: 15 March 2013, 11:40 »
you can fix them, I've had issues with 3 of the 4 door modules on mine and it was just a case of resoldering the cracked joints
Offline HJGTI
« Reply #6 on: 15 March 2013, 14:33 »
Really so could be that simple ??
Offline beppe2672
« Reply #7 on: 15 March 2013, 22:11 »
It's a pain in the arse to get to it, door card off, window out, window winder mechanism off, then you need an m8 spline/triple square bit to take the door module out, don't use a torq bit as you will round off the screws! When you finally get the door module apart and split, inspect all the soldered joints, re solder any that look dodgy. There should be a DIY for this somewhere on the forum.
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #8 on: 15 March 2013, 22:12 »
Feel free :wink:
Offline beppe2672
