Author Topic: What cat with a ss exhaust and ss manifold?  (Read 2183 times)
Offline murraymint
« on: 13 March 2013, 22:55 »
As above what cat is best to use with a ss exhaust system and a ss manifold, a oem steel cat or a ss decat?
josh
VW BUSH
Re: What cat with a ss exhaust and ss manifold?
« Reply #1 on: 14 March 2013, 09:20 »
Something that's legal. ..... :grin:
Offline murraymint
« Reply #2 on: 14 March 2013, 09:35 »
 :whistle:
josh
Offline boneybradley
  • Back in a Mk3...
« Reply #3 on: 14 March 2013, 09:49 »
this is an impossible answer... I prefer to keep the o.e cat but others will say de-cat or sports cat's are better
removal of the cat does make a difference in noise and may give a few more horses. But I have found it also moves the power a bit higher up (and can affect torque output due to less back pressure), sports cat's are possibly best alround but for there cost, there an expensive mod for little gain!
« Reply #4 on: 14 March 2013, 09:50 »
What makes you want a stainless manifold, the standard one is not that restrictive, given the choice I would run a standard manifold and cat then a decent system (Jetex is a good choice)
Offline murraymint
« Reply #5 on: 14 March 2013, 12:38 »
I'm lookin at a ss manifold as mine sounds like it cracked and also the heat shield noise is starting to annoy me
this any good?
http://item.mobileweb.ebay.co.uk/viewitem?itemId=120916392088&index=19&nav=WATCHING&nid=51176229466
josh
Offline Khare
  • The bear that khares
« Reply #6 on: 14 March 2013, 12:41 »
Read it properly mate....
Offline Foreveryoungaus16v
« Reply #7 on: 14 March 2013, 12:43 »
Removing the CAT will make no difference in HP (will increase noise) the same as fitting a sports CAT as the
standard CAT is not restrictive on a standard 16v
163 BHP (TSR POWER RUN)
Offline whileoceanasleeps
  • patience comes to those who wait.
« Reply #8 on: 14 March 2013, 12:54 »
i think you should go for a ss decat, more noise and backfires!  :evil:
« Reply #9 on: 14 March 2013, 12:58 »
Agreed, SS would be the better bet.  Just remember fitting it will not give u better performance just a louder
noise :smiley:
