Author Topic: Epic turbo noise..turbine  (Read 3100 times)
Offline travisreeve
« on: 13 March 2013, 20:56 »
Hi guys.. I have a 20vt in my mk1 golf AGU k03 turbo.
When i boot it the turbo spools up and then seems to make an epic turbine kinda sound pretty dam loud aswell. Im taking it this is a problem the car seems to be boosting okay but i have no gauge to confirm this and some times in 4th 5th at low revs the car seem to want to judder
Any thoughts on this would be appreciated :)
Offline tech1889
  • Mk2 GTI FTW !!
Re: Epic turbo noise..turbine
« Reply #1 on: 13 March 2013, 21:01 »
vid ?
Offline travisreeve
« Reply #2 on: 13 March 2013, 21:05 »
I would love to mate but i really dont wanna risk it if its something bad.. Best way to describe it is it sounds like a turbine of a plane aha
Offline tech1889
  • Mk2 GTI FTW !!
« Reply #3 on: 13 March 2013, 21:08 »
What intake you running ?? A cone filter will make the turbine louder.. if enclosed intake you shouldn't really hear much.. You checked for boost leaks ?? and correct boost ??
« Reply #4 on: 13 March 2013, 21:08 »
Could be a turbo bearing
Offline DubAndDubber
« Reply #5 on: 13 March 2013, 23:46 »
So you want help but you don't want us to tell you what the problem is?
Mk5 Golf Gti 06'
Offline tigerj360
« Reply #6 on: 14 March 2013, 09:56 »
Think he means he doesn't want to risk running the car to take a video mate.
Offline travisreeve
« Reply #7 on: 14 March 2013, 14:53 »
^^^ thats the one
Offline hobbiniho
« Reply #8 on: 14 March 2013, 17:33 »
remove the TIP and see if the shaft has any movement. a little movement up and down and side to side is fine movement in and out is not
Offline Dave_IOW
« Reply #9 on: 14 March 2013, 18:10 »
Is the noise on boost or as you come off?
Project: Mk2 20vT trackslag
Daily: Mk2 GTI typ19
