Author Topic: squeak every time i let the brake pedal up or handbrake off ?  (Read 1522 times)
Offline spudboy6
  • Just like a golf ......
when the engine is running , so i press the brake pedal , when i lift my foot up off the pedal i get a squeak ,
same again if i pull the hand brake up and let it down i get a squeak ,
and if i pump the pedal i get a little tune of squeaks , same if i hold the button in on the hand brake and pull it up and down ,
really annoying my now and i always thought this was the brake biast / compisating valve under the rear axle but it went away at one point now its back ,
odd thing is the noise comes from the middle under the car not from a drum asfar as i can tell ,
anyone had any experiences ?
Offline Bellend
Take the drums off, clean adjust and grease the contact points.
Where all my moneys went.
Offline Jasikasisback
it is dirt or grime on the drums.
i had this. just do as posted above
and problem should disappear. it is not an mot fail and is just annoying.
Offline sharki786
  • GOT BOOST??
I know this wont help but you could get onto x factor and make a good tune with your brakes :evil:
*****MK3 Anniversary*****
*****MK4 GTI T*****
