Author Topic: just a heads up  (Read 6647 times)
Offline JC
  • Back in the North.
Re: just a heads up
« Reply #10 on: 12 March 2013, 21:11 »
From what I've heard from my boss, (Tester) it's actually a grey area. There isn't anything coming into the m.o.t for failing diesels without a Cat, but there is for petrols. So as I see it, some will fail you, some won't. You just have to go to the right guy ;)
Equally how is the tester to know what car is fitted with what. Take a DPF for example; not all cars are fitted with one even if they are the same car, built in the same year with the same engine etc etc
THIS . yet another fcuk up by vosa that will no doubt be added to the " pending " items due in the next changes to the test.
I would be more concerned about the changes to the rear brake imbalance and future limits   :lipsrsealed: :whistle:
Offline Hoggy
  • Mk4 GT TDI 150.
Re: just a heads up
« Reply #11 on: 12 March 2013, 21:24 »
It tells you on the m.o.t printout sheet what the vehicle is fitted with or without and what vsi limits apply :)
As for the brake limits, fill the boot with bricks ;)
Offline Rhyso
Re: just a heads up
« Reply #12 on: 12 March 2013, 21:25 »
Good job the limits are high then as mine passed it easily  :smug:
Offline scarr89
  • Mk4 Golf, DERV FTW!
Re: just a heads up
« Reply #13 on: 12 March 2013, 22:30 »
Can someone explain why bricks would help? Brake IMBALANCE?  :undecided:
Offline Hoggy
  • Mk4 GT TDI 150.
Re: just a heads up
« Reply #14 on: 12 March 2013, 22:43 »
I can help here ;) It's not for imbalance, its to get a higher brake reading if thy lock up too early, the heavier it is, the less likely it is to lock up :)
Offline scarr89
Re: just a heads up
« Reply #15 on: 12 March 2013, 22:48 »
Ahhh, with ya  :wink:
Offline JC
Re: just a heads up
« Reply #16 on: 13 March 2013, 06:30 »
thus missing the point totally.
only the fronts have a % imbalance allowance at the moment.
however, they are bringing it in for the rears too.
Load away, if you have an imbalance it wont help at all  :grin:
