Author Topic: Problems after new cambelt/Water pump  (Read 2518 times)
Offline Perryd84
  • MK4 Golf 1.8T 20V GTI
« on: 12 March 2013, 08:32 »
Just had new cambelt and water pump fitted but now I'm having some wired issues  :undecided:
1: The car doesn't start on first try unless I give it a bit of gas then it picks up?!
2: While driving when I come to a stop the car idles erratically dropping then going up, it does this a few times before settling?!
Probably nothing to do with the new belt and pump but thought I would mention it just in case.
Any help would be great as it's a massive pain when I forget to put my foot down to start it and also well embarrassing in a packed petrol station when the car don't start and gives off a massive starter motor scream just to draw even more attention  :embarrassed: :angry:
Oh one more thing on VAGCOM it gives back "engine coolant sensor" Intermittent nothing else?!
« Last Edit: 12 March 2013, 08:38 by Perryd84 »
1999 GTI 20V 1.8T AGU : Stage 1 Map : Forge Split-r (Full recirculate) : Forge TIP : Pipercross Viper CAI : 40mm Apex lowering springs : Custom interior trim : 2009 Ibiza sport Gear Knob : Custom Mats : bora sport instrument cluster : Bora Vents :
VAGCOM - South London only
Offline GTi_James
Re: Problems after new cambelt/Water pump
« Reply #1 on: 12 March 2013, 08:37 »
get some codes up matey and have the starter replaced, 140£ at a VAG specialist or 100£ yourself, also check your battery down halfords with their free checks and how long ago was the alternator done?
Offline Perryd84
« Reply #2 on: 12 March 2013, 08:42 »
Yeah had it on VAGCOM comes back with the engine coolant sensor intermittent.
I put new battery in couple years ago can't be knackered already?
Offline GTi_James
« Reply #3 on: 12 March 2013, 08:56 »
cold weather doesnt help battery life at the mo, get the temp sensor replaced with an OEM one
Offline Perryd84
« Reply #4 on: 12 March 2013, 09:32 »
Cheers I'll take a trip to the stealers get a sensor and see what happens.
Offline GTi_James
« Reply #5 on: 12 March 2013, 10:39 »
well before you go anywhere give the sensor a clean and see if that helps?
Offline Perryd84
« Reply #6 on: 12 March 2013, 10:55 »
Good shout! Cheers mate!
Offline Nino
« Reply #7 on: 12 March 2013, 10:58 »
ever thought that the timing might be out a tiny bit?
Current - MK6 GTi Edition 35
Offline GTi_James
« Reply #8 on: 12 March 2013, 11:02 »
+1 could cause massive issues if this is the case, but considering it should of had worst symptons shouldnt it?  :undecided:
Offline Perryd84
« Reply #9 on: 12 March 2013, 12:23 »
What would cause that? fix?
