Author Topic: help!!!! fast idle on hot start up  (Read 1599 times)
Offline maggott84
« on: 11 March 2013, 19:46 »
hi i have a mk4 golf gti 1.8t with a problem that is driving me mad :angry:.
when started in the morning from cold the car runs perfectly as it should, il stop and switch off for a few mins (i.e. popping to the shop), il jump back in and start her up again and the revs rise to 2000rpm for a few seconds then idles at 1200rpm.
there is also a slight hesitation on the throttle when parked.
i had it plugged into a vagcom and it showed that the temp sender was faulty so i changed it and for about 4 days it seemed like it had cured the problem untill friday last week when the problem came bk :cry:.
if anyone could help me it would be much appreciated thanks :grin:
Offline Immortal
  • 1.8 Turbo GTI (AUM)
Re: help!!!! fast idle on hot start up
« Reply #1 on: 11 March 2013, 20:50 »
I had the same thing start a couple of weeks ago.
Initially a scan said temp sensor, so like you I swapped it out. Then it came back a couple of days ago (along with a major flat spot in my boost), now it appears to be the lamba sensor
Hope this helps
Offline maggott84
« Reply #2 on: 11 March 2013, 21:07 »
hi mate thanks for ur reply i have had a feeling it might be a lamda sensor. iv got it booked in at a garage call C.G Proformance on friday i shall let u no the out come. have u changed the sensors if so has it made a difference? thanks again :smiley:
Offline maggott84
« Reply #3 on: 13 March 2013, 19:04 »
does any one no if a EGR valve or a cold start valve would corse the problem i am getting ??
