Author Topic: 16v golf Belt whats it called??  (Read 2776 times)
Offline H Singh
« on: 11 March 2013, 10:08 »
Hi guys,
my belt that goes upto the alternator snapped on me this weekend. So i need to put a new one on. But i cant do that until i take off the belt thats at the bottom as the alternator belt sits behind it. Whats that one called? i was thinking to replace that at the same time.
Offline Agreeable Slick
  • Unit
Re: 16v golf Belt whats it called??
« Reply #1 on: 11 March 2013, 10:27 »
If it has PAS then it's that belt. I can't remember if the water pump is run off a separate belt.
Offline oakgreener
« Reply #2 on: 11 March 2013, 10:30 »
They'er all called auxillary belts these days. They were, and are still some times refered to as fan belts. You need to look at the size that is printed onto the the belt. It will be something like 10 x 735 or 11 x 935. The first number being the width and the second the total length.....Good luck :smiley:
Offline H Singh
« Reply #3 on: 11 March 2013, 10:36 »
The water pump is run off the alternator belt thats snapped. I havent got the number on the belt tho i was going to just go to vw today to order it. Hopefully they will give me the correct one!
Offline oakgreener
« Reply #4 on: 11 March 2013, 10:54 »
Just checked mine, which is an 8v PB engine. The alternator belt is  11.2 x 866 and the water pump/power steering belt is
10 x 735
Offline H Singh
« Reply #5 on: 11 March 2013, 11:22 »
okay thanks buddy, mines it a 16v KR engine would anyone have the belt number for that one?
Offline nrm69
« Reply #6 on: 11 March 2013, 21:23 »
I had the same issues about 18 montyhs ago and ended up buying the wrong belt first time around:
http://www.golfgtiforum.co.uk/index.php?topic=217436.msg2008277#msg2008277
Offline H Singh
« Reply #7 on: 15 March 2013, 14:15 »
Finally got it fixed but had an issue finding the correct belt size. So the size i needed was 9.5x630mm but closest i could get was 9.5x625mm so 5mm smaller but was plenty of play!
All fixed and back on the road :)
Offline Mr Blue
« Reply #8 on: 15 March 2013, 15:34 »
Good stuff Sengh  :wink:
